Feature Line Dynamic point after "slope between points" function was set
I was created dynamic feature line (FL) from auxiliary surface (rectangular mark) and after that i made set grade function between these points. At the moment it fits perfect, but if you have changes on auxiliary surface it affects only dynamic related points. It means that "set grade" point stays static and each time requires manual input.
The idea is to extend "set grade" functionality to add dynamic recalculation after dynamic points was modified. That will considerably reduce modification time. The idea is suitable since 2018 civil 3d version after relative elevation was presented.
Answer Day
Rail Community
