Extract solid from surface - add Property Sets
If our TIN surface has Property Sets with auto properties or by formula and we call the command "Extract solid from surface", then I would like a replica of the property sets of the surface in the 3D solid.
Obviously, all these properties will be manual in the 3d solid.
I mean: automatic process to create manual properties with the same name and the value will be taken from the surface user property.
Currently we cannot pass a TIN surface to IFC file so we need its equivalent 3d solid with the same user properties.
