Export surface to solid in a cut/fill situation of two surfaces
When trying to create surface solids between surfaces that intersect (cut/fill), the solid creation results in an error.
Details in this knowledge article:
http://knowledge.autodesk.com/article/Error-No-solid-can-be-created-based-on-surfaces-when-trying-to...
The idea is to make it possible to create  3D solid for intersecting surfaces.
2 Comments
Karsten.Saenger
Autodesk Support
I must revise this idea. Further testing with surfaces proved that it is already possible to create 3D solids from surfaces that intersect. In my test file the issue was something with the surface geometry. It finally worked after exporting LandXML files for the two surfaces and import these in a new DWG and extract the volume surfaces.
18615686728
我试了一下,仅填方可以提取,既有填方又有挖方的情况不行
Answer Day
Rail Community
