Edit sections in section view Because of eliminate unnecessary grade break point
when we create surface from point cloud data, because of much more points, , there can be a lof of unnecessary detail in section view. when we use band for grade break points ,labels  are overlapping. we can set this with weeding factor but, when we create surface reports from "futureline reports in reports manager" there isnt any options for weeding factor.
instead of this, we can create simple line from our aligment and then create section view,. after that we can edit surface section which  is created from point cloud. we can draw nearest geometry  with optimal grade break points.for all section. we can make this edit on each section view. after that we can export a new "edited surface" from this section view.
note: in surface edit command, we can simplfy surface with removing edge, and removing points. but we cant control which points and which edges will be remove. but  if can we use idea that ı tell, we can edit surface  which station we need to use.
Answer Day
Rail Community
