Drive command (in the corridor contextual ribbon) fails.
It does not make sense the "Drive" command in the corridor contextual ribbon.
If you select a corridor and you press that button in the ribbon, the command ask us a "Corridor Feature Line". If you pick some of them, the command fails. It does not happen anything.
(Even, that command doesn´t aks us to select a polyline3D  or alignment) when that command can use those types of entities.
We have to select first an alignment or Corridor FL and then run the command Drive to work fine.
So, fix that command in the corridor contextual ribbon or hide it.
Answer Day
Rail Community
