Drawing lines perpendicular to polyline segments
Refer to this thread: http://forums.autodesk.com/t5/autocad-civil-3d-general/lineperpendicular-from-polyline-segments/m-p/...
Relevant command is LINEPERPENDICULAR
  • Please provide the ability to draw perpendicular lines from any location on a polyline (e.g. a mid-point not just a vertex) without having to draw intermediary reference lines.
  • Similarly, allow the ability to directly reference either adjoining segment when drawing a perpendicular line from a polyline vertex. The current tool appears to only be able to reference the last segment drawn.
- Mick
2 Comments
joantopo
In adittion, in the "Drafting settings":
http://exchange.autodesk.com/autocadlt/enu/online-help/ACDLT/2012/ENU/pages/WS1a9193826455f5ffa23ce2...
I would add a new tab called "Direction tracking" (now AutoCAD has "Polar tracking")
In this new tab we were able to type a direction,pick on 2 points or directly pick on a segment of the polyline.
Next to this, a button if we want to plus 180º (for orthogonal direction).
This way allows us retaining a direction and you only need to enable the "Direction tracking" (pressing a control(function) button in the keyboard, for example, F12) when you need that direction or the orthogonal direction.
So, you don´t have to select the segment again.
I think that the "parallel" snap object should be called "parallel direction", and a new snap object called "perpendicular direction".
joantopo
In Istram Ispol software we can do that.
There are 2 functions (if we press the button right of the mouse, to show the contextual menu):
-Enable /disable "perpendicular direction".
-Enable/disable " parallel direction".
There are 2 functions (they are saved in variables), to catch the direction
-Cath perpendicular direction.
-Cath parallel direction.
So, when you enable the "perpendicular direction", then it is tracking with the perpendicular direction(the last value for that variable).
This is the reason why I proposed the "Direction tracking".
Answer Day
Rail Community
