Drainage Surface Structure Ponding Areas
I know you can do this manually, but I mize well ask. IT would be a great idea if there was a way (as the user performs drainage calcs) sometimes we need to see the catchbasins ponding area above a structure. For instance, some places like to see where 6" inches of ponding of a structure is on the grading plan. Usually we have to use User Contours to pull this off.
I can see if the user was doing storm calcs in Hydraflow Storm Sewers or somewhere else, That there could be a default field within the structure that can be used as a ponding elevation. Where once the pipe network is referenced to a surface, the user contour would show up automatically.
I do not know if I am saying this correctly, but it is along those lines. This just helps with flood routing to show on our plans.
1 Comment
neyton_
I developed an app to calculate drainage and sewage pipenetwork.
One of things of it do, is calculate excavation, see:
Autodesk exchange apps:
http://apps.exchange.autodesk.com/CIV3D/en/Detail/Index?id=appstore.exchange.autodesk.com:c3drenesg_...
or:
http://tbn2net.appspot.com/showprog?progid=C3DRENESG4
Answer Day
Rail Community
