Disable regions by clicking in the drawing
If we select a corridor in the drawing, an option in the ribbon to pick on regions and disable them.
4 Comments
joantopo
I think this would be also valid to enable a region.
The only trouble is we can have the same area in several BaseLines (with the same Alignment) in our corridor.
To solve this: because there is more than one solution (region according to the BaseLines), it would be interesting we were able to set  this in the corridor properties to define the priority of the BaseLines for this command.
joantopo
Similar than the command "EDITCORREGIONFREQ" which is in the ribbon to add frequency in the regions.
You pick on an area and then Civil 3D automatically identifies the Region, and the command is live until you press ESCAPE.
joantopo
It is really annoying and we waste a lot of time opening every time the parameters tab (in corridor properties dialog box) to enable/disable regions of the corridor.
I think this feature should be implemented in 2018 release.
joantopo
About my first comment:
"To solve this:
To solve this: because there is more than one solution (region according to the BaseLines), it would be interesting we were able to set  this in the corridor properties to define the priority of the BaseLines for this command."
I think the best would be a "Selection Cycling" for BaseLines (in the same selected corridor) just like AutoCAD objects.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Answer Day
Rail Community
