Hello!
I am rail track designer and I use Civil 3D for several years. It would be extremely useful for rail track designers if we could set a different styles for alignments and profiles depending on stations range. It is very common in case of modernization or renovation of track that there is continous track geometry (continous alignment and profile), but different scope of construction works on different stations ranges. For example, on the first range it could be only tamping, in the next track replacement, etc. Usually it should be shown in different color or line style in drawings.
Consequently, it would be useful if there were possibility to set different styles for corridor feature lines depending on the stations range or region, as well as the code set styles of the cross-section.
