Datum Shift Option
Datum Shift Option
Add an option in the style or object (check box and amount) to shift a profile or pipes.
The object would just be displayed at the elevation shift (typically 5 or 10 feet down). Labels for the object show the correct actual elevation.
This would save me from making objects no plot styles and then tracing them to shift down or having duplicate objects that display.
-John
3 Comments
rdbauer50
Can you give an example/use case when you would do this? I am not sure why you would want this? Not saying it isn't a great idea, just not sure the exact use.
erwebsite
If you need to show multiple profiles on the same view that have relatively the same elevations.
Examples on a profile view:
Prop. Centerline of Road Profile
Prop. Left Ditch Profile
Prop. Left Storm Pipes
Prop. Right Ditch Profile
Prop. Right Storm Pipes
rdbauer50
Does the "Create Superimposed Profile..." or adding offsets to your surface profile cut not work for this? Pipes already allow you do add them if they are on the alignment or not and it also allows you to then add station offset labels to those pipe and structures. Not saying that this might not be useful, but for this case, it seems like there is already the tools needed. If I am not understanding the use case, please elaborate with some pictures maybe.
Thanks!
Answer Day
Rail Community
