Create points: Import file (Apply a Description Key).
The Create COGO points dialog box has the button "Import points" to import a file.
In the dialog box of the "Import points" we can apply several operations such as Elevation adjustment, coordinates Transformation, etc..
I think that "Apply description keys" operation should be also available here, not only when we import a DataBase Survey for Survey Points.
I know the workaround of the majority of the users is using directly several Points Groups with a defined point style for each code point but I would also like to have this option to add an own style for each point.
3 Comments
joantopo
I have seen that this option is currently available but only from the context menu:  You must select COGO points in the drawing and then press right button of the mouse to select "apply description keys" from the context menu.
I think this option should be also available from the dialog box when we import a points file.
Jeff_M
Joan, make sure the Disable Description Keys option is set to False and the DK's work fine.
joantopo
Yes, I was wrong.
I though that we had to select a Description Key Set (similar than Survey Prefix Figure DataBase) when actually, all Description Key sets are used together according a priority.
So, when we import a point file and that feature is enabled (Disable Description keys = true), yes, Description keys are applied from all Description key sets.
Sorry, I was confused.
Admin can delete this post or move it to solved, sorry.
Answer Day
Rail Community
