Create FeatureLine from Survey Figure.
We need a fast way to do this, where we can select several FL and then create new Survey Figures from them.
Right now, the "Create FeatureLine  from objects " doesn´t accept the Survey Figure entity whereas the "CreateGrading" obejct, creates a new FeatureLine from a Survey Figure...
However, in an old post, I said that Survey Figures and Feature Lines should be derived from a parent class. An example is the Point category which has COGO points and Survey Points and the point style and label point style are shared.
Moreover, when we create a Parcel Segment from a FL (or corridor FL), the Parcel Segment is not dynamic from the FL.
1 Comment
MSteeleGQA9T
Yes please!  I lose hours and accuracy trying to recreate the geometry created when the survey data is processed.  Just make them selectable in "make feature lines form objects"
Answer Day
Rail Community
