Create Cogo points from corridor
The tool of creating cogo points from the corridor is amazing and could be perfect if the user had the option of check/uncheck all codes.
By default, all codes are checked but at the end of the day the survey crew needs specific points to the stakeout in the field.
Also when you use our "homemade" subassemblies from Subassembly Composer, the number of codes is big. So every time needs to uncheck a lot of checkboxes.
Answer Day
Rail Community
