Coordinate transformation
I would like to make coordinate transformation via Helmert or Afin method. It shoul be used for any civil 3d objects and point files. Transformation matrix and point pairs should be saved and re-used any time.
3 Comments
Pointdump
Cemil,
More details please.
Dave
CemilYuksel
Points
FIRST SYSTEM(SOURCE)
SECOND SYSTEM(TARGET)
y
x
Y
X
N.1
545430.463
4351434.836
545408.237
4351252.452
N.2
445865.410
4321096.840
445843.458
4320914.823
N.3
415295.590
4183714.550
415274.203
4183533.151
N.4
424726.460
4227139.000
424704.990
4226957.195
N.5
409159.410
4292887.300
409137.693
4292705.159
N.6
410387.800
4292275.410
410366.064
4292093.342
N.7
412089.110
4293697.380
412067.373
4293515.364
N.8
412454.580
4289205.300
412432.975
4289023.387
N.9
412762.560
4342802.110
412740.812
4342619.838
N.10
413090.820
4295316.740
413069.013
4295134.744
Hello Dave,
Thank you so much for your attention. The points on the list above, they are
same points on earth however they are on different coordinate systems. This
coordinates or objects can be transformed to each other system by using
Helmert similarity transformation, Affine Transformation or Projective
transformation. Coordinate pairs or transformation parameters can be saved
and Load when it required.
Please take look matrix calculation for Helmert Similarity Transformation at
below.
x1
- y1
y1
x1
X1
VX1
a
Y1
VY1
Matrix A(2nx4)=
b
Matrix X(4x1) =
c
Matrix L(2nx1)=
Matrix V(2nx1)=
d
xn
- yn
Xn
VXn
yn
xn
Yn
VYn
n:Point umber
ax1-by1+c=X1+Vx1
ay1+bx1+d=Y1+Vy1
N=ATPA
n=ATPL
X=N-1n
P:Unit Matrix
axn-byn+c=Xn+Vxn
ayn+bxn+d=Yn+Vyn
Pointdump
Cemil,
From the Help Section:
"You can define your own transformations based either on a grid file or on parameters you specify."
http://help.autodesk.com/view/CIV3D/2016/ENU/?guid=GUID-CBFAC20A-F512-4D52-8663-D46DCAA83544
Dave
Answer Day
Rail Community
