Contour label line size
From the feedbacks received on this forum, it appears that there is no way to control the size of label lines (contour lines labelling on a surface). It would be interesting to have a setting to control this to know precisely how many contour lines are to be labelled with a single click (I guess in most cases, users only want one).
Users can currently find their way around this:
  • changing the object scale (decreasing the scale factor by 10 or 100 for instance) when adding labels and setting it back to its actual value when done
  • adding one label, editing the label line size and then copy/pasting it.
None of these options allow to change them once they are created though.
Answer Day
Rail Community
