Construction Note Management
There is no current way to easily handle the callouts and management of construction notes. The main problem is that there is no consistent way to manage them between AutoCAD and Civil 3D objects. For AutoCAD, people use fields, multiple xrefs and viewports... Civil 3D labels do not utilize any of these methods.  I have played with using Property Sets to mange them within Civil 3D labels but the current state is very limiting.
I would like a solution that will work across AutoCAD and Civil 3D. It is possible that property sets could be used if generic label styles supported them. Or possibly go a route similar to AutoCAD Architecture.
1 Comment
ChrisRS
I think that this is a duplicate of:  Adding Construction Noted (Bubble Notes)
The previous Idea had 52 votes and was marked accepted on 2-23-2016.
Answer Day
Rail Community
