COGO Point as 3D Point in ACAD
It will be good when we export C3D File with COGO points into ACAD , the COGO Points become 3D Point instead of Block reference.
It is easy when we  create points from surface  using civil 3d with full settings  and to share that file in cad format.
2 Comments
TerryDotson
Before doing the export, use the ...
Command: _AeccConvertPointsToSdskPoints
... to create old Softdesk point blocks.
BlackBox_
Excellent guidance @TerryDotson, as usual!
1+  Autodesk should absolutely integrate this as an optional setting during Export.
While they're at it, they should also properly handle MLeaders during Export:
https://forums.autodesk.com/t5/autocad-civil-3d-forum/exporttoautocad-troubles/m-p/6731955#M324054
... And account for COGO Points on locked layers during Export:
https://forums.autodesk.com/t5/autocad-civil-3d-forum/exporttoautocad-troubles/m-p/6740928#M324424
Cheers
Answer Day
Rail Community
