A lot of times, I use the same Code Set Style for the assembly and for the corridor sections.
The issue is I do not want to show the same labels in both. (Why do I have to do a copy of the code set style?)
For example, I want to show "code" labels in the assembly and do not show them in the corridor sections (I show the grade).
And when I select a Label style, I can´t define different components in a "View direction". View direction is not designed for labels.
So, in the code set style, I would like to select labels in 2 columns (one of them for View direction= plant) and the second column for View direction= Section.
Another issue if I use the same code set style for corridor and an assembly. In "View Direction=Plant", links are the corridor in plant and the links of the assembly.
So "link styles" should have more "view directions" = Plant (corridor), Plant (assembly), Model,Section,....
