Clockwise property in the alignment entity
It is stupid that we cannot edit completely an alignment entity after it was created....
¿Where is the bool Clockwise property?
This is a "floating curve from the entity end" with the parameters length and Radius (and Clockwise by prompt).... try to change the clockwise later.. you can´t.
In Istram Ispol or Clip Toolsa is simple, you just have to put a sign before the Radius value to stablish the clockwise. (Negative Radius is a curve on the left side)
The Clockwise is a property in the C3D API.............
Answer Day
Rail Community
