Clip view to concentrate on one area.
I'd like the ability to "clip" the view of a Surface using a Limit or Bounding Box. Similar to the way Cyclone can create a limit box for a point cloud.
I work with rehabbing road corridors and have complicated existing surfaces with curbs, curb cuts, driveways, walls, ad  nauseam. I then have a large Dreffed Lidar Surface. When I need to investigate an anomaly in the existing Surface. I like to rotate the model to inspect the area in question. However. To use 3D orbit to look at one driveway cut. I have to wait for both Surfaces to slowly regenerate. I've tried Clips, Crops and Masks. None work well especially with a Dreffed Surface. What I'd like is something temporary that could easily be expanded or shrunk. It would be great if it worked on the whole modes but just limiting the surfaces would be great.
1 Comment
AllenJessup
Correcting a typo. I meant;
It would be great if it worked on the whole model but just limiting the surfaces would be great.
Answer Day
Rail Community
