Clip corridor regions with another region.
When i design e.g an island or a sidewalk ramp, instead of trying to fit everything with targets , it would be great if i could draw another baseline make a region and then subtract the two regions.
1 Comment
joantopo
We need more commands(or buttons) to apply certain operations about Regions and BaseLines for Corridor Objects in the "Parameters" tab:
* cut/copy a region of one BaseLine to another Baseline in the same corridor.
(when you cut/copy a region-- the assembly assigned for that region should retain the offset/elev and surface targets).
*cut/copy a BaseLine from a Corridor to another Corridor...
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/copy-move-a-baseline-to-another-corridor/idi-p/...
Answer Day
Rail Community
