Change object's layer property by changing layer in command line
Currently, we can change the layer by typing the layer name (or a portion of it) in the command line, waiting a second, then pressing enter (or spacebar).
However, I propose adding the ability to change a selected object's layer, if one is selected, during this operation as well. So for example, if we are currently at layer 0, have a line selected, start typing "wal", it would offer to change the layer to "A-WALL". If we hit enter it would change the layer to the proposed one (which is what it already does) and also change the layer of the line we have selected to the proposed layer, too.
4 Comments
Which version of Civil 3D are you doing this in? In my version when you start typing at the command line Civil 3D will auto complete the command name and not layer names.
Peter Funk
Civil 3D Product Manager
Autodesk, Inc.
ebsoares
Hi, Peter.
I'm using 2016 version, but I believe this is an innate function of plain AutoCAD.
When you start typing a command (usual mode), AutoCAD will attempt to figure out what command you want before you finish typing it, and it will give as many options as it can find. You can have it look for layers (and blocks, etc.) as well.
Click on the "Customize" button next to your command line (the wrench looking icon) and select "Input search options...". See below:
I needed to have my cursor actually in the command line for the layer options to work, and I never do that.
Peter Funk
Autodesk, Inc.
ebsoares
Hummm... that's strange. For me it works fine, like any command - I can just hit enter, so with everyone in our office here.
If I type in "Line" it will give us options for commands (like "LINE"), layers (like "A-Wall-Line"), blocks, etc. And we can just use the up-down key in keyboard keys when there's more than one option and hit enter.
No so with your version?
Answer Day
Rail Community
