(C3D and SAC) : Select/ De-select Report Messages directly from the Subassembly properties window.
Although you want to improve Event Viewer with select/de-select according a type of message (error/warning or information) or according a partircular report message I think that it would be interesting as a complement that the user were able to select/de-select Report messages directly from the Subassembly properties Window. (From here it overrides the Event Viewer settings..)
Due to 2 Report messages can be the same type and the same String (Description), maybe in SAC the Report Message component should generate an ID for custom Report Messges (  CRM1, CRM2,CRM3,....)
And due to some Report messages are created by Autodesk then they will be RM1,RM2, RM3,....
So the new tab "Report Messages" will be a DataTable with the following columns:
- Checkbox column to select/de-select it.
- ID of the Report Message
- Custom or stock Message
- Description of the message.
1 Comment
TimYarris
Thank you for your idea. We will review this idea as other customers comment and vote on it.
Answer Day
Rail Community
