Breakline data also for Survey Figures.
FeatureLine and Survey Figure is nearly the same object but they don´t have the same properties.
In the FeatureLine properties, Statistics tab, we can find: BreakLine Data,
Breakline Data
If the feature line is used by any surfaces as breakline data, the following list is displayed.
Surface
Displays the name of the surface.
Breakline Group
Displays the breakline group.
However, if you open the Survey Figure Properties, you can´t get that data. We can also add a Survey Figure as a breakline to a surface... why not to show this information also in the Survey Figure Properties?
In fact, if you use a Survey DataBase in the Survey Module, objects are Survey Figures which you add them as a breaklines in your surface.
Answer Day
Rail Community
