Axis from network (Pipe Networks)
If you have created a pipe network in Civil and have set the sewer end position with a rule on e.g. the outer wall of a structure, then the "Axis from network" function will no longer work. (DWG in the appendix).
It would be desirable if the axis calculation would consider both the pipes and the structures as support points. I.e. always in the middle of the start and end points of the pipes + the center of all structures.
1 Comment
f_furger
The version 2024 of C3D is relalesed and still the same problem:
