Automatically add CUIx file after reset settings to default
After using the Reset Settings to Default too (AdMigrator.exe), it would be nice if C3D could check for existing installations of Raster design and either automatically add back the .CUIx file and support path or at least prompt the user (in the case of multiple versions of RD). Seeking to simplify the following existing procedure:
  1. Enter the CUILOAD command and locate aecco.cuix and add it to the list.
  2. Enter OPTIONS, click the Files tab, and add the Support File Search Paths for Raster Design. By default, these are:​
    ​C:\program files\autodesk\autocad raster design 20XX
    C:\program files\autodesk\autocad raster design 20XX\help
Answer Day
Rail Community
