AutoCAD: allowing Calculator in the Dynamic Input
This in the dynamic input in AutoCAD:
(Enable Dimension Input where posible)
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
But we can´t add mathematical expressions in it such as "+" ,"-", "*" or "/".
This would be very useful for example if we are using some osnap (in the drawing is the end point in the polyline), and we just want the half length.
In MicroStation, the AccuDraw has the pop-up calculator to add 2 modes: mathematical expressions and directly expressions such as: sen(45).
I miss some type of Accudraw compass in AutoCAD.
1 Comment
joantopo
This scenario only works if I remove all value in the gap (empty gap) and I type manually all the value : 7739.9467/2 (neither I can copy and paste it).
But we can´t add mathematical operations after the result value.
Answer Day
Rail Community
