Attributes with Background masks
My wish is for attributes to have an option for background masks
3 Comments
Reza.Esfandiari
I have the same wish. Smiley Indifferent
Reza.Esfandiari
Advocate jcp
in reply to: Rank
Re: Attribute with background mask?
If you set the attribute to be multiple lines then is edits as mtext and the background option is available.
gherrmanRQ549
True, but then when you add the block to the drawing, you have to go into the text editor for every text attribute and turn the background mask on. It would be nice if there was a way to add the background mask to the attribute in the block editor so that when the block was added to the drawing, the background mask was enabled by default.
Answer Day
Rail Community
