Assign a profile (from LandXML file) to another alignment.
I explain the following case:
You have a drawing file (dwg1) with an alignment.
You copy this drawing file, so you have (dwg2).
You create a layout profile for this alignment in dwg1.
Now, from dwg1 you export this profile (you must also export the alignment) to a LandXML file.
You open dwg2 drawing and import this LandXML file.
Immediately, CIVIL 3D creates a new alignment and its profile but you CAN'T assign this profile to the existing alignment.
In my opinion, C3D should allow us managing the importation of objects contained in a LandXML if we want to create a new alignment and its profile or directly the profiles to an existing alignment in the drawing if it is possible, I mean, if the length of the alignment is at least the same length of the profile.
Maybe there are others objects where we could also stablish this.
4 Comments
joantopo
Or maybe a new command about creating a design profile from a LandXML file where the user can choose it from the LandXML wizard
joantopo
Or even within the same drawing file.
Example:
You select a layout profile from the ToolSpace (or from the profile view), then you press right button of the mouse to show the context menu: "Copy profile to alignment", and finally you select an alignment in the drawing to create automatically that layout profile in the selected alignment.
neyton_
1) export the landxml of both dwg
2) Replace the alignment profile definition in the xml file using Notepad
3) import the landxml again
joantopo
@Anonymous
Yes, I knew that but what happens if you are already using that alingment in a corridor as a BaseLine.
Will I have to remove that Baseline in the corridor?. That is not serious...
Answer Day
Rail Community
