arc entity closely 0 length
There is an issue in Civil 3D with the length of arc entities in the alignments.
If we draw a fixed arc with 3 pass-through points, the length of the arc cannot be minor than 0.007 meters. Not 0.0001 meters for example.
If you draw a :
floating curve with a spiral (from entity, radius, length) off a line.
And you only want the spiral, the curve cannot have a length minor than 0.007 meters.
And... where is the "floating spiral" directly in Civil 3D?
With fixed lines by 2 points, the length can be even 0.00001 meters, but we cannot do this for arc entities.
2 Comments
doni49
I have to wonder what is the purpose of such a small segment.  0.007m = 0.2756 inch.  To put that in perspective, we're talking about the size of a typical pencil eraser (the little round one found on most pencils -- not the ones you add later).
joantopo
Well... basically is for my app:
http://forums.autodesk.com/t5/autocad-civil-3d-general/lam-linked-alignments-manager-my-new-addon/td...
Sometimes I want "invisible" entities, so if they have a length roughly 0, then I consider it "invisible".
Answer Day
Rail Community
