Allow Survey Queries to be written in the survey database without locking it.
The database should only be locked for updates to the database. You should be able to add or edit the queries interdependently. You should still be allowed to save them in the database, but multiple people should be able to build quires and use the survey database at the same time. The database should only be locked for point edits. Imports, moving / updating points, etc.
Also,
I've seen this in another post, but you should be able to export the query into a point group. I know if you query user defined attributes in a point group directly it doesn't retain them, that's been broken since the beginning of C3D (not sure if it was ever fixed), but you could take the point numbers from the survey queried points and automatically build the group that way. There has to be a better way to go from survey database to point group for symbolizing and layering.
Answer Day
Rail Community
