Allow Surface Build Definitions to be edited from properties window
Be awesome if all of the build definitions where exposed to the regular autocad properties window. This would allow angle/length to be changed on multiple surfaces at once!
Maybe even the operation build order could be exposed when you have once surface selected?
2 Comments
ceethreedee.com
Be great if the "build definition" options for surfaces where available in the properties palette.
This way surfaces build operations could be edited without entering a dialog box! But it would also allow multiple surfaces to be changed at once. Particularly useful for setting "MAX TRIANGLE LENGTH" and MAX TRIANGLE ANGLE. to create boudaries.
Status changed to: Gathering Support
Duplicate of: http://forums.autodesk.com/t5/autocad-civil-3d-ideastation/allow-surface-build-definitions-to-be-edi...
Peter Funk
Sr Product Manager
Civil 3D
Autodesk, Inc.
Answer Day
Rail Community
