Allow Read Only Access to a Survey Database
Why can't you access the database in read only mode if someone else has it locked for editing. Just because I'm running updates to it, it shouldn't limit others from accessing it.
What if my updates are not critical to their work. They should be able to continue to work and than run an update after I'm done. Not block them because it's locked.
Answer Day
Rail Community
