Allow modification of ViewFrame Orientation by direct angle input or direction
I would like to be able to modify the ViewFrame Orientations by direct input of Angles or directions.
Currently the only option for changing the ViewFrame rotation after the viewfames are creates is by dragging the rotation glyph around. How ever, if you toggle on your Ortho snap the viewframes are never quite North-South or any angle you've set your crosshairs to (close but not quite). So, you are always just approximating your ViewFrame twist.
Instead of having the orientation greyed out.  Allow it to be modified to some preset values like:
  • North, South, East, West
  • Along Alignment
or user defined values like:
  • Angle,Azimuth,Bearing
Option 2 for data input would be to have an input box pop-up when you select one of the glyphs to be able to input the value on screen for:
  • AeccViewFrameStation
  • AeccViewFrameRotation
  • AeccViewFrameCenter
Answer Day
Rail Community
