Adding different blocks for cogo point marke style depending on view direction
I think it would be awesome to expand the current Cogo Point Marker style display options to allow for separate custom blocks to be specified for the marker depending on the View orientation (Plan, Model, Profile, or Section).
For example, if you have a Cogo point representing a Sanitary Sewer cleanout or Access point, etc. The marker style would have an option to specify one marker block for “Plan” View perspective, but my idea is to have access to other block options for different views like Profile and Section View when the Cogo points are projected to a Profile View and/or Section View.
I hope others would agree that this would be useful.
1 Comment
joantopo
Yes!!
And support for multi-view block. You would select the same block in each view of the style but C3D would use properly the corresponding view of that muti-view block.
https://forums.autodesk.com/t5/civil-3d-ideas/override-display-representation-in-a-multi-view-block-...
But currently C3D does not "support" to multi-view blocks in the mark styles.
Answer Day
Rail Community
