Add or Remove pipe from Spanning Label
I would like to be able to add or remove pipes from a spanning label that I've already created, similar to changing the selection set of a structure table.  I only noticed needing it for Plan view labels, but it should apply to Profile and Section labels as well.
This should also apply to Pressure Pipes, once you can even do spanning labels in pressure pipes...
Answer Day
Rail Community
