Add new section tool should interpolate properties between closest two sections
When new section is added to corridor or simply you add some targets to your corridor, all the sections come with default parameters which are predefined in assembly. But pretty often in complex corridors  some parameters are defined for specific ranges using corridor section parameters editor tool. The problem is that if new section is added in that range it takes the default values of assembly and it would be nice if it could interpolate  parameters value between two closest xsections and be inserted that way.
Answer Day
Rail Community
