Add 3D Solids to Surface
Add workflow, similar to adding 3D faces to TINN surface, for 3D solids. Algorithm would take top of solid surface, removing overhangs and adding proper vertical face "correction". The idea conceptually would be like draping a sheet over the object.
An example use case would be adding structures (3D Solids) to an excavation surface so that is can be used as a base for structure backfill type calculations. An example of the menu is attached.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it
Answer Day
Rail Community
