ability to filter a dynamic corridor feature line
Instead of changing the corridor frequency or convert the corridor FL to static it would be fantastic if we could use also the tool "filter" for a dynamic corridor FL.
Maybe the parameters to apply a filter (basically to erase vertex) to the dynamic corridor FL should be part of the properties of that FL.
2 Comments
TimYarris
Status changed to: Gathering Support
Hi @joantopo . To clarify: are you looking for functionality that is similar to the WeedFeatures command for grading feature lines? I understand you want it to be an automated property of the corridor feature line, but am wondering if you are requesting the end result.
joantopo
Hi Tim.
I don´t know what would be the best way:
If  the command "WeedFeatures" also allowed dynamic corridor feature lines OR adding those parameters of the WeedFeatures dialog in the same FeatureLine properties dialog.
In any case it would be necessary a button to restore the dynamic corridor feature line to the beginning with all its vertices.
Answer Day
Rail Community
