A reverse command of "CreateSurfaceWaterDrop"
It would be interesting a tool that was the reverse operation of "CreateSurfaceWaterDrop".
In my case I need to know the crest of an existing road with crown. I have only the TIN surface, no alignments, etc..
If I show the contours with very detail (0.02 meters for example)  then I can draw a polyline but I would like to have a tool for this directly.
Even another solution would be: create an horizontal surface later create a Volume surface with horizontal an Existing ground surface and use "CreateSurfaceWaterDrop" because I will have the Volume Surface in this shape "V" so the crest will be the sag this time.
Answer Day
Rail Community
