2018- Improve "Section View Drafting buffer"- Retain elevation of the objects.
I love the "Section View Drafting buffer" but I would like to add more things in it.
For example, if we draw an AutoCAD circle of which center is in the elevation 80 and then the section view is edited:
- Change the Vertical Scale.
-  Change the elevation range , especially if we have set in auto - elevation range.
I would like that the buffer was in the charge of moving vertically that entity to its properly elevation (retain elevation).
Due to we generally draw a lot of entities (circles, COGO points, polylines,..) on the section views, maybe we could set this in a manager (for each section view), to select which entities we want to "retain" its elevation.
This feature also for a Profile View.
Thanks.
Answer Day
Rail Community
