Hey guys, this is somewhat a trivial question that I could dance around but would rather understand why it is not working correctly.
I am doing 2D drawings so I prefer all of my lines to be flat to avoid line-work and hatching issues. Normally I would complete my drawing, highlight the entire thing and flatten it all at once.
I then accidentally found that if you right click on "all points" then properties, then overrides; you can check the 0.00' elevation box and make all of your survey points 0.00' elevation at once. It even shows at the bottom of prospector that all of my survey points are at 0.00' elevation.
The problem is that I am still dealing with line work issues such as a line that should be dashed coming in solid. I then click on the line........properties and it shows the starting Z to be -9.99E+27. I am assuming that is some type of exponent value. If I flatten the line it then correctly shows up dashed. But why am I having to do that when I have my zero elevation override checked and all survey points show up a zero elevation.
