XREF text showing as frames
KMercier_C3D
Advisor Advisor
KMercier_C3D
When I xref one specific drawing (A.dwg) into another specific drawing (B.dwg) all of the text from the xref drawing (A.dwg) only displays as frames. But if I xref the same drawing (A.dwg) into a different drawing (C.dwg) then all of the text from the xref drawing (A.dwg) displays as text as expected.
Detaching and reloading the xref does not help. In the problem dwg it doesn't matter if I xref it as an attachment or an overlay. I've run an audit on all the dwgs. The scale of all the drawings are all the same. The drawing units of all the drawings are all the same.
Has anyone seen this behavior and know how to get the xref text to show? (I can not share drawings.)
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
hello,
have you checked the text frames setting?
tframes = off
and then regen the drawing.
good luck
nonbeard13
msisler
It looks like the sysvar QTEXT is on.  Have you tried turning it off?
You CAD!
KMercier_C3D
@Anonymous: TFRAMES were off, toggling them on and off again and REGEN( and REGENALL) did nothing
@msisler: QTEXT was on, toggling it off and REGENALL fixed it! Thanks.
Pronouns: She/Her
mzionE27X2
Community Visitor
Community Visitor
that fixed it - thanks
