Civil 3D Forum
Xref Inserting At Incorrect Coordinates
2 REPLIES 2
aphealyVB233
933 Views, 2 Replies
aphealyVB233
Hello. I have two drawings, A and B. Both are correctly positioned when overlaying the Geolocation Map and other Xrefs. Drawing A is correctly inserted in drawing B, however, trying to insert B into A, B comes in at slightly the wrong coordinates. INSUNITS, INSBASE, Block Scale, etc. has all been accounted for. Please see attached. I am trying to insert Grading and Drainage into Site Layout.
Tags (4)
Labels (1)
  • xref
2 REPLIES 2
user181
in reply to: aphealyVB233
user181
The UCS in the drawings is not set to world.  You should set them both to world UCS and change the insbase to 0,0 in both before xrefing
aphealyVB233
in reply to: user181
aphealyVB233
Thank you so much. I tried setting it to world previously but did not realize the base point changed after that. Cheers.
Rail Community
