In our current project, we are working on representing the cut/fill slope with 2D hatch on the Xref, which I will use for the sheet. However, the client would like us to Xref the Civil3D model file to the sheet and show the cut/fill area as illustrated in the image below. This process will require significant time to freeze or hide all unnecessary layers. Does anyone have an optimized solution to streamline this task?
Thanks in advance.
Solved by m_kingdon. Go to Solution.
Solved by EliANewlines. Go to Solution.
Generally when I only want to show a few layers in a xref, I work backwards: I freeze all the xref layers, then unfreeze the ones I want to show
Just data reference the cut/fill surface. Or Xref your model and turn every layer off apart from your cut and fill surface. Either workflow should only takes you minutes.
Mike Kingdon
Civil 3D Zealot
