XREF Contour Labels Showing Too Big in Layout
fernando.lopezSZ649
fernando.lopezSZ649
So I am trying to work with a file that has a xref of the contours and its elevation labels. The contour labels show properly in the xref file in both model space and layout, but in the file I'm working on the display way too big on the paper space, even though they show fine in the model space. I have tried to change the label settings and made sure the style wasn't annotative. When I change the scale to 1" = 1' it works momentarily when I switch it back to 1" = 50', but the labels blow up once the model regenerates. Here is a screenshot for reference. Thanks in advance
Pointdump
Hi Fernando,
Welcome to the Autodesk Forums.
Can you post your drawings?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
neilyj666
contour labels are always plotted in mm (if you are metric) so the text is always, say, 3mm high. this means at a 1:500 scale (metric) they will look good but at 1:2500 they will look way too big even though they are still 3mm high.
Ensure all your files are at the same scale in model space as the scal you will be plotting and you will see what the plot willl look like
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
fernando.lopezSZ649
That is an option I considered, but the contours are an xref from a drawing of another company we are working with, and we aren't really supposed to modify it. They set their model space to 1' = 20' and I am supposed to be plotting in 1" = 5' with my model space at 1:1, any ideas on how to modify the labels without messing with the xref?
fernando.lopezSZ649
Here are the files... Just might need to change the xref path
m_kingdon
It looks like the cogo point labels are perhaps acting strangely.  There are a lot of label styles in this drawing also!
If you don't need the labels showing, you could add a point group at the top and add a style override so all point show <none>
Mike Kingdon
Civil 3D Zealot
