A coworker has a workspace in 2020 CAD with the older tools all set up. How do I import that workspace into my computer to use? Thanks
The following AKN article summarizes the various ways you can migrate settings between two versions.
I would suggest looking at the "Unsupported settings migration" and "Use the AutoCAD CUI editor" sections of the above document when working with Civil 3D.
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the above response help answer your question? If yes, please click on the "Accept as Solution" button in that reply so this helps other users in the community find the solution too. Thanks!
