Workflow for Grading Two Different Pad Elevations to Existing Grade
Hello everybody! I am a college student working on my senior project. Basically, we have two separate pad elevations on top of an existing grade surface. Our goal is to grade these down to the existing grade surface.
We have already created two separate feature lines for the two pad footprints. Our thought process is to add these feature lines to the same site (called FG Pad), then create a grading group for this site, and create separate grading objects by selecting each feature line one at a time. Is this correct? So far, we have applied this methodology to the theater pad already and you can see the white grading object at the south end of the pad. The issue here is that it is not showing up as a green and red grading object, so we cannot see where the cut and fill regions are. I am imagining this has to do with the layer that the grading object is on, am I correct?
Attached is our DWG file for reference.
Thank you!
