I'm looking for a general recommended workflow to convert dwg to dgn with proper mapping of linetyes, fonts and layer/level colors.
I have dgn's and seed files from the client. Our C3D layers, lines, colors do not match.
1. Is it best to just create a dwg envirinment the mimic the dgn or use the remapping option in the Export Civil Drawing command?
2. Where and how does one create this remapping file in csv format? I get the csv extension but what is the syntax? Is this file created manually or in C3D?
3. A bit off topic but when I open microstation the level color do not appear as defined in the level manager. All levels appear to display in white. Is this like a live plot preview? There are not overrides applied to the levels.
John Mayo
