Why would acad.exe be waiting for acad.exe?
AllenJessup
Mentor Mentor
Message 1 of 15
AllenJessup
Program is locked while trying to convert 3DFaces to Surfaces. This type of action where the program freezes for hours before completing an operation is too common. I admit I'm converting 181,000 faces. But STILL....
Allen Jessup
CAD Manager - Designer
Replies (14)
Message 2 of 15
AlmasSuljevic
Autodesk Support
Autodesk Support
Hi Allen,
I tried creating surface from 3D Faces using one of the tutorial files and it seems that it all works fine with 4080 3D faces. Only one acad.exe shows up in the Resource Monitor. Can you upload your drawing with 3D faces for others to try?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 15
AllenJessup
Hi @AlmasSuljevic
I tried again this morning and the process finished. I'm not sure of the time because I started it before going into a meeting. I'm trying to create an AutoCAD compatible drawing because I'm working with @john.vellek on another issue. I'll be trying to upload it to a box he set up later today.
Thanks for the response.
Allen Jessup
Message 4 of 15
AllenJessup
Almas,
Does this look normal to you? I selected a vertex on a polyline and had to wait a couple of minutes for the program to respond.
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro K4000
Samsung SSD 512GB
HGST (WD) 512GB drive
Allen Jessup
Message 5 of 15
AlmasSuljevic
Autodesk Support
Autodesk Support
This does not look normal to me. Seeing that you have almost 8 GB of memory usage seems problematic to me. Not sure if it's in the drawing itself or something else. Have you tried WBLOCKing that drawing and importing into new DWT. See if that shows smaller memory footprint and if it works better.
Almas Suljevic
Autodesk, Inc.
Message 6 of 15
AllenJessup
I tried that last week along with a clean reinstall of Civil 3D. The drawing size is 144MB.
Allen Jessup
Message 7 of 15
AllenJessup
This is a QSave that's taken over 5 minutes.
Allen Jessup
Message 8 of 15
john.vellek
Hi @AllenJessup,
Perhaps a stupid question, but where are you trying to save your file? are you working locally ore on a network?  A file that large might give you some real problems if you experience any kind of latency or packet loss on your network connection. LIkewise a flashdrive or USB drive might also introduce some issues.
I would try the same operation working on a local drive to see if the behavior persists.
John Vellek
Message 9 of 15
AllenJessup
Hello @john.vellek
I'm working from my C: 0.5TB SSD. Should be fast. But.......
Allen Jessup
Message 10 of 15
AllenJessup
@john.vellek
I'm working from my C:, 0.5TB SSD. should be fast. But.....
Allen Jessup
Message 11 of 15
AlmasSuljevic
Autodesk Support
Autodesk Support
Do you have any data references and xrefs there? By any chance your drawing is bloating after each save?
Almas Suljevic
Autodesk, Inc.
Message 12 of 15
AllenJessup
No. Neither. The only way I get semi-decent performance to set to Plan with a 2D Wireframe. I've tried both rolling back and updating the Nvidia drivers and don't see much difference. Turning off Hardware Acceleration helps a little bit. But when doing animations I need to leave it on. Thanks for keeping up with this.
Allen Jessup
Message 13 of 15
AlmasSuljevic
Autodesk Support
Autodesk Support
With hardware acceleration on set HQGEOM variable to 0 and see if that improves performance slightly. I think the drawing being that large, it will be hard to have excellent performance, especially if there are large surfaces, complex corridors, sections and all that. Do you see similar behavior with smaller files? Can you try creating surface from 3D Faces only in one drawing. You may try copying 3D faces from that drawing and import it into new blank drawing and test. That will tell you if program is problematic or your dataset. Good luck.
Almas Suljevic
Autodesk, Inc.
Message 14 of 15
AllenJessup
Thanks. I'll try that after the latest Anipath animation finishes. I don't have any complex (or any) Corridors. I do have a large Surface created from Aerial Lidar and ground based Laser Scanning. The Lidar was created from a Geotiff and I exported a grid of points from the Laser scan Point Cloud and attached the N,E,Z ASCII file to a Surface. Then pasted into the Lidar surface.
Allen Jessup
Message 15 of 15
AllenJessup
HQGEOM was already 0. I've had complex drawings lag but never to this extent. I've never used Material to anywhere near this level before. Is it normal for Materials to slow the performance way down?
Allen Jessup
